save/load locations problems || save IR map doesn't work
  • save/load locations problems || save IR map doesn't work
    Each save button should remember it's own last location. It used to be that way, but not anymore. For example I save my image to location X and I loaded a BG HDRI from location Y. Then I want to save a new render, and the dialog goes to the map Y instead of X. Very annoying because you need to browse each time all over again.
    Save IR map does not work. I selected auto save to a certain location, and after render was finished, nothing was saved. Maybe it's the same for LC, didn't try that. Why isn't there a save button so that you can save the IR map AFTER the render has finished (if you forgot to turn it on before the render)?
    Re: save/load locations problems || save IR map doesn't work
    Hi Wouter- I can get a IR map to save ok here. You do need to set it up ahead of time with a name and so on with the Browse button. Lat time I tried it, having Auto Save on and leaving the path empty leads to a crash. It seems to me that if you check AutoSave you should have to browse for a file and flll in the blank with a valid path, it just does not make sense as it is. Same with 'From File' If that is blank when you click the radio button, it should force a Browse operation it seems to me. A Save button for after the rendering would make sense as well.
    -Pascal
      yes the savving of irradiance maps was resolved last week. It will be in the next build. As for each file box remembering its previous location, I'll get it in as soon as I can
      [edit]
      Pascal I take it you are not using Beta9 if you can save irradiance maps?
      Joe Bacigalupa
      Developer
      Chaos Group
        [edit]
        Hi Joe- yes- beta 9
        -Pascal
